Command Trac??? Can some one explaine?? | Ford Explorer Forums
BAYDOG
Phelps NY
95 Sport
My Ex has command trac, and I guess it was an option. What exactly is it, and how does it differ from standard 4x4.
Are you sure its command trac and not control trac.
its a trademark
Control Trac is Ford's name for the type of 4wd/Auto system that they use for the Explorer.
If you are interested in the operational details, there is some limited information in the Chilton manual and some more detailed information on Alldata http://www.alldata.com (but you have to subscribe).
Basically it is a system which uses sensors and an electronic clutch pack in the transfer case to control how and when to apply power to the front wheels.
Hehehehe, yer right..... Control Track it is. So whats the difference???
I think the difference is that instead of 2wd, 4hi, and 4lo settings; it has auto, 4hi, and 4lo. I think what dogfriend was trying to say is that in the auto setting, the computer can vary the amount of power it sends to the front (I think 5-50%).
Yeah what alec said, but 95-96 models had 2wd, Auto 4X4, and 4lo. Where as the 97+ has Auto 4X4, 4hi, and 4lo
curiousity question
I'm interested in more of the operational details of the system, but the only information that I have ran across are in the two sources I listed above.
I ordered a factory manual from e-bay ($45 used) so I'm hoping that there will be some more info in there.
Does anyone have any other sources which explain in detail how the system works?
Yes, there is some good information in that thread. I think that I have also read some other threads here regarding the control trac system as well.
I realize that you can search for threads here. I am also interested in other sources as well. I think that the patent search is an excellent idea, I will probably look that up as time allows.
What else do you want to know specifically?
The Control-Trac is essentially a part-time 4X4 in automatic mode in "AUTO". When your rear wheels begin to slip, the front wheels are engaged and you have 4X4 until the traction is restored in the rear end.
Many people confuse this with AWD (All-Wheel Drive). It is not quite the same, it is acutally a Automatic 4 Wheel Drive.
From the Ford's brochure, the Control-Trac can transfer almost all of the power to the front, if the situation dictates. Otherwise, it is in 2WD, waiting for the rear wheels to slip whenever the AUTO is selected.
i don't
I'm interested in how the system works on the "engineering" level for lack of a better explanation. I'm not trying to solve a particular problem.
It would be analogous to the book on Ford Fuel Injection and Engine Control. In that book they discuss the problems to be solved, the theory and design of the system which attempts to solve the problems and the intended (and unintended) result of the operation of the system.
I'm interested in this from an engineering perspective.
The original patent info probably would contain some of this info, but they are typically pretty dry reading.
Here's something I saved from a Looooooooooooooong time ago. I found it very interesting. Sorry but it is very long. It is an answer to someone's question a while back.
Explanation of 4WD Systems
This is normal operation for 4X4 AUTO mode of the Control
Trac system. When Ford originally introduced the system
in the '95 Explorers, it had a 2WD setting, but all you had for
4WD options was 4X4 AUTO and 4X4 LOW, there was no
option for locking it in to 4X4 HIGH (the system was this way
in '95 and '96). In '97, Ford changed the Control Trac system
so that it was always in the 4X4 AUTO mode and then allowed
4X4 HIGH along with the 4X4 LOW setting. In some engineering
articles I read on the Control Trac system (from an Automotive
Design magazine we receive here where I work), Ford originally
made the Control Trac system run in 2WD normally because they
were concerned about the reliability of the transfer case clutches
if the system was allowed to continually engage and disengage
them all of the time in normal driving situations (not only snow
and ice, but rain slickened roads as well). Through further testing
of the transfer case during the '95 and '96 model years, the
variable lockup clutches in the Control Trac transfer case were
found to be so "bullet proof", that Ford decided to change the
system at the beginning of the '97 model year to run normally in
4X4 AUTO mode (giving you somewhat of a computer controlled
all-wheel drive system). This also allowed them to do away with
the vacuum operated disconnect in the front differential that did
the switching from 2WD to any of the 4WD modes (as it was in
the '95 and '96 Explorers). Ford supposedly has rigorously tested
the Control Trac system and has found that the variable lockup
clutches in the transfer case are capable of more then 1 million
full torque lockups (going instantly from zero lockup to full lockup
while transferring 500 ft/lbs of torque through the transfer case,
much more than any Explorer engine could ever put to it) without
having any major amounts of wear on the clutch plates (according
to the article both Ford and Borg-Warner, who builds the transfer
case, have tested the system to this degree and have come up
with the same results). This system is also used in the Expedition
and has been so reliable (and has an industry reputation for working
so well) that companies like GM are now offering this same transfer
case as an option in all of their SUV's and even have it as an option
in their full size pickups.
The Control Trac system is only used on V6 powered
Explorers. The V8 powered 4X4 Explorers use a slightly different
transfer case that has a viscous coupled clutch system. This system
always operates in AWD mode and normally sends something like
35% of the power to the front axle and 65% to the rear axle. Under
slip conditions it can send more power to the front axle if needed and
less to the rear. This system does not give you any option to
completely lock the transfer case (as the 4X4 HIGH mode does in the
'97 and newer Explorers) and also has no LOW range available.
For the 90 some odd percent of the Explorers that are never actually
taken "off road" and are only used in normal street driving conditions
in snow, ice and rain this is not really a problem.
The lurching you feel is normal as the transfer case sends
power to the front wheels. The severity of the lurch depends on
several factors including how hard you are on the throttle, how much
power the system decides to send to the front wheels, and how
much traction the front wheels are able to get when the power is
applied to them. It can range anywhere from hardly being noticeable
to being hard enough to push you back in your seat and can be
accompanied by (as somebody else mentioned) a loud banging
noise. The way the system is designed, this constant cycling of
power from the rear to the front wheels, other than maybe being a
little annoying, should not cause any damage to the system.
Setting the system to 4X4 HIGH, which simply causes the variable
lockup clutches to go into full engagement which sends power
equally to the front and rear axles, will help in this situation.
However, if you really think that you can smell something that is
getting hot under these conditions when using the 4X4 AUTO mode
and it is giving you the indication that something isn't normal, you
should probably have a dealer look at it while it is still under
warranty, better safe than sorry.
command trak is a jeep x-fer case
yes this is an interesting article
Jason_25
Thanks, this is an interesting article because rather than just saying that Ford switched the system to 4 auto all of the time, it discusses the reasons why they first designed the 2wd option, the testing of the unit and the reasoning behind removing the 2wd option.
I'm kind of curious how the sensors and computer work to determine the percent of power (I understand the basics). Like which inputs are given to the computer, what assumptions are made regarding the inputs, etc.
Basically the Control Trac is a type of feedback control system, similar to the engine control system only applied to a different problem.
Jason....Thanks, thats what i was lookin for.
