compatibility of transmission need help | Ford Explorer Forums
ndavis426
York Springs, PA
1999 XLS
I have a 99 explorer I replaced the transmission with one from a 98 still don't work right....is there a difference between the sohc and ohv explorer or is there some others non compatable issue that I'm not seeing
Maybe the replacement transmission was defective or there could be an issue with a sensor on the engine, exhaust or wiring. What kind of issue are you experiencing? Did you install a used transmission?
