sanlucar
- July 23, 2006
- Houston TX
- Ford Explorer 2000
Hello there:
I have been getting Missfires on cilynder 3 and getting rough idle, three weeks ago I took the spark plug on # 3 and it was soaked with gas, then I replaced the spark plug and it took care of the problem.
Well, the CEL came on again, this time I took the spark plug on # 3 to see if it was wet like before, this time it was dry, it seemed ok.
There is no rough idle and I cleared the code last night, so far no CEL.
Today I run a compression test on all cilynders and I got the following:
#3 130
#2 160
#1 160
#4 170
#5 170
#6 170
I assume cilynder # 2 is the one next to cilynder #3 and # 1 next to # 2 all on the same side. On the other side I assume cilynders 4, 5 and 6 are located.
Should I be concerned that the compression is low on # 3?, how do I fix this.
Thanks for the replies.
#3 130
#2 160
#1 160
#4 170
#5 170
#6 170
