xploder
- March 12, 2000
- Olathe, KS
- 1995 Eddie Bauer...
Ok, ok ill try to explain it so its not to confusing. My climate control on my 95 Eddie Bauer is "tempermental". It is hot outside so I put it to 65 degrees, and push the automatic button. It blows really cold. As I raise the temp. It does not get any hotter. I will have it up to 85 and it will still be blowin A/c. Then once you put it on 90 it will start to come from the bottom blowing heat. So far it has blown heat at 80 and 85 degrees
(very very rarely). Right now it doesnt matter so much because it is in the 90's this week but I want to know how or what to do to fix it. Is there a way to reset it...or has anybody else had this problem? Thanks, in advance
