elkhunter
- August 24, 2004
- Big Horn, Wy
- 91 Eddie Bauer Explorer
Okay Glacier and Brain, here goes. I finally got the transmission out and something is really strange. I could have sworn I pulled the converter maybe a 1/4 inch to bolt it to the flexplate. I have the whole thing out on the floor and I can't even wiggle the converter. Some small things indicated someone had had it out before. I found out it was Aamco (?). Besides the rock solid converter there is a small area under the converter that looks like something had attempted to run down from the shaft area and it is as hard as epoxy or fiberglass. I don't remember anything like that in your transmission diary. I can wiggle the converter and shaft up and down a bit and when I turn it something is rough like maybe bearings. Now I am wondering if someone cobbled it together long enough to get rid of it. If someone did glue the converter in with something it probably means I am fighting a losing battle. Let me know what you think of this if you don't mind.
