OSUV
- December 5, 2006
- Findlay, Ohio...GO BUCKEYES!!!
- '98 Red/Gray 2DR Sport
Hello everyone!
The fan blower switch on my heater/AC control panel is dying. I have high gear only! When I want airflow, I have two choices...off or 'Blast me out the door'. I know that the easy fix would be to just replace the standard climate control panel with the same. But I recently received a free 'electronic' climate control panel from the same model year Explorer as mine. And it looks to be brand new.
Can I uprade from the standard boring 3 dial climate control to the more attractive and more functional 'electronic' climate control? The connector openings in the back of each panel are different, so it's obviously not going to be a plug and play situation.
The vacuum hoses appear to be the same. Only the wiring appears different. I have the connectors with stubbed out wires for the new electronic climate control panel. All I need to know is, can it be adapted and if so, how can I get a hold of a wiring diagram for each panel so I can properly match the wires from the current wiring harnesses/connectors to the new harnesses/connectors?
By the way, My EXPO is a 1998 2DR Sport 4X4 w/AUTO & 4.0 SOHC!
I appreciate any advice i can get on this. But if you don't know the answer, please don't act like you do. That benefits noone on this prestigeous forum.
Thanks in advance and GO BUCKEYES!
