Rodeo Joe
Elite Bostonian
- August 29, 2003
- Frankin, MA
- 1997 XLT
I've had a small coolant leak on the front passenger side of my 4.0 SOHC that I can't find. Nothing serious yet, looks like just a small drip over the freeze plug there. I've searched and the heater control valve seems to be a common problem, I'll check that when it stops snowing!
Temp gauge and heat are fine.
Last week, it threw the code. Again, after searching, the main culprit seems to be the intake gaskets.
I'm not that familiar with the intakes (if they run fluid through them or not), but would a bad lower intake gasket cause a coolant leak in that area?
Joe
Joe
