captainjack
- April 1, 2005
- Old Bridge, NJ
- 2007 Sport Trac Ltd. 4.0
2007 ST, 4.0, 65,000 mi., purchased used with unknown service history. I had a very small coolant leak, probably better described as weepage, appearing on the bottom right of the radiator. From every angle top and bottom I was unable to see the source or trail, just a couple of drops on the plastic block (radiator support?) visible from underneath. Inside the radiator cap everything visible was perfectly clean and the coolant looked fresh so I tried a tube of the dry powder stop leak and have not seen a drop of leakage in about 750 miles. As a point of information the owner's manual mentions that Ford coolant stop leak tablets are available so I doubt that the product will plug up the radiator or heater core unless it was horribly neglected previously.
The intermittent roaring fan continued until I noticed a few small dried spots around the radiator cap which seemed to indicate leakage or venting at the cap. The cap, its spring and seal appeared fine and there had never been any sign of overheating or high reading on the temperature gauge but I replaced the cap anyway---500 miles later the fan remains quiet.
If the leak returns I won't use more sealer and will get the system pressure tested but so far so good and I just wanted to share my experience.
