Coolant leak in block | Ford Explorer Forums
94Sport5Sp
River Hills
94 Sport
Hi:
My 93 x has sprung a coolant leak. By the looks of it, the leak is above the drivers side motor mount. On the drivers side just in front of the mount there is a sender switch (low oil I think) and above that is where the coolant is leaking from.
Anybody know if there is a frost plug up in that area? Anybody have a picture of that area? From the looks of where the coolant comes from, the leak is below the head and above the oil pan.
Additional info: Coolant leaks without pressure. So with radiator cap off and by putting water in rad the water will leak at the above spot.
Thanks for your thoughts.
PaMnd
