jsgoofn
- July 13, 2015
- Beautiful Colorado
- 2022 Explorer ST-Line
Well, I got in my Ex, started up as usual, drove about 1 mile when it lost power (fail safe mode), lights all lit up and the the dreaded "Coolant Overheat" warning comes up. Temp shows pegged. Fortunately, I was still close to civilization and able to pull into a gas station. Checked coolant - it was a little low and the engine was barely warm. It's 20 degrees outside. After topping off coolant and waiting a while, still shows maxed out temp. Called for a tow.
Anyone else had this issue? And what was done to fix it? Apparently, the temp sensor can go bad. Thanks for any input/advice.
