MuscleJunkie
- April 14, 2007
- '00 Ford Explorer LTD AWD
That looks nice. We did not go quite as far when trying the Contour Setup. The poor balance on the aftermarket Contour units that were tried created a vibration in the whole chassis (very slight but noticeable) that could never be resolved.Sorry to hear the Contour setup didn't work out for you. It is definitely a bit of a PITA to setup correctly. The advantage to those fans is the extremely high output capability of the fans themselves. For example, I have an 800 hp supercharged 5.0L Mustang and live in southern Arizona where the ambient temperature is currently 110F. The Contour fan assembly literally overcools the engine with the AC running, to give you an idea of the massive amount of air they move. I estimate it must be around 3000 cfm with the restrictions in front of them. I'm actually using a Derale 2-speed 17" single fan with a full shroud for the radiator in my Monty, so don't feel bad giving up on the Contours!
To get those Contours to work correctly, 2 major tasks have to be performed, both of which are not really that much fun. First, a shroud has to be developed to completely capture the entire radiator core surface area. In my case, I've fabricated aluminum sheetmetal to achieve this and also function as a mount for the fan assembly. Care has to be taken to ensure adequate distance from the core and minimizing airflow losses around the core, so it is not a trivial undertaking in terms of design or fabrication. I have used a waterjet to cut sheetmetal and used a CNC brake to bend flanges to achieve the correct spacing.
The 2nd task is the electrical aspect of the Contour fans. A mere fuseholder will not suffice as the fans will literally pull over 120A of in-rush current if they both start up at full power. The only way to reliably accommodate this extreme electrical load is to use a 100A or larger circuit breaker. The gauge of the wiring has to be up to the task. The relays being used for each fan must be able to support the loads reliably and an electrical tie-in must be made to support the AC function as well.
Here's a shot of what I fabricated for the Mustang's radiator:
The Flex-A-Lite 180 has since worked without any issues (or vibrations.
