03Explo20
- January 4, 2013
- Jonestown, Pa.
- 2003 Explorer XLT
Just finished flushing my cooling system. I changed the t-stat, hoses, refilled, then started the truck to let it heat so the t-stat would open and purge any air that may be present.
I had the heat on high (idling) and the gauge would rise to the normal range but it would not throw any heat. I decided to take a small drive around the hood to see if that helped it heat and it sure did!
The temp reading in the truck went all the way up to high just 100 feet down the road, the check engine light came on, then the t-stat must have opened as the temp gauge went right back down into the normal position and the truck started throwing great heat!
I used a Motorad Fail Safe T-stat in the truck.
I'm thinking maybe a big air pocket possibly caused this and when it relieved itself everything went back to normal?
I did the distilled water multiple flush routine then filled the degas bottle with two and a half gallons of straight Zerex G05 AF. How long should I want until it would be mixed thoroughly with the water so I can check the freezing rate?
One additional thing, I put the new t-stat in the same direction as the one I removed. Does it matter the position it would be in? This Fail Safe had this little brass "valve" on it that I put facing towards the engine. I don't think this matters but want to be sure anyway!
