Mike65
- December 31, 2013
- Horsepasture, Virginia.
- 2005 2WD Regular Cab F150
I tried to do a search here with no luck on an answer so here goes. I have a 99 Sport w/the 4.0 SOHC engine, next weekend I will be changing the thermostat, the upper & lower radiator hoses, & replacing the coolant. I was told by someone that the SOHC engine should only use the yellow coolant, is that true, or should I be using something else?.
