CopyKat's Copy Cat B4 | Page 5 | Ford Explorer Forums
Status
Not open for further replies.
:afro:
Went out to a spot called Pollycore Rd.
Plagued with electrical problems left me dead in this spot.
Just a plain cool picture.
Getting some work done. The trans developed a whine so I parked it untill I could get my spare trans rebuilt.
What better time to get this thing going and get it off my work bench.
Shifter mockup
Test fit everything in the truck. Still need to swap the trans.
looks good. how hard is it to modify the front case?
Here are the installed pictures.
Rear driveshaft angle will only get better when I remove 3" of lift out back.
Tested that out yet? :thumbsup:
What doubler it that? DD, stubler, or homemade?
nice lookin bii. i like the flex you got out of the costum setup :thumbsup:
and the doubler and the "ford" on the hood.
when you go up to 20" of travel, will the wheels bind if you jump or get both front wheels off the ground? looks like there's already alot of camber change. and if you ask me, it looks like you have morethan 14"s of travel. mine's at about 14 and it doesn't drop nearly as much as yours.
It could be 14 could be 18, I haven't checked in a while. I'm going to be lowering the front 1-1.5". I want to get rid of the coil spacers I have. I just dropped 3" of lift out back. I measured about 13"+ travel from the rear. I was measureing for shocks so thought I would do it.
Once I lower the front I'll be revamping the front mounted shock position along with the rear mounted one. This way the 12" and 14" stroke shocks work better. And with the the new RS9000XL's I have on order, I'll need to have more shock body clearance.
oh yeah that doubler cam out nice.whne you took the 3" of lift of the rear did it stop binding?.....so when your ready i'll mail up two transfer case's.and you can use the same box, to mail that one down to fl.just playing...yeah you should do a build thread just for the doubler.so other's can see the monster you've created.and attempt to do the same.
Since the bumpers have now been sold it's time to work on new ones.
Here is a sneek peak.
Status
