lobo411
- September 14, 2011
- 1996 Explorer 4.0 OHV
Edited: problem solved. Severe front timing cover coolant leak was resolved w/ K-Seal.
Temp gauge was showing erratic overheating and the problem proved to be a failed, 2 year old Motorcraft radiator cap w/ only 4000 miles on it. Can't trust nothin' these days!
1996 Explorer 4.0 OHV 172k. Salvage title. Some drunk chick plowed into the rear while it was parked on the street one night, and pushed it 30 feet up the street and into two more cars. The cops were amazed. Her car was destroyed. Mine just needed to have the bumper attachment points on the frame straightened, which I accomplished with a sledgehammer and a makeshift anvil. Love that about these Explorers!
Pretty clean body for a 22 y/o truck, clean interior except for the usual driver's side seat leather wear, lots of recently replaced parts in the last 2 years (fan, fan clutch, a/c low pressure valve, blend door, both driver and passenger tail window seals, new headlamp and turn signal plastic housings, radiator overflow tank, high-mount third tail light converted to LED, new battery, new water pump, etc...).
Recently passed smog with flying colors.
But recently...electrical issues: overhead console and radio displays blank out randomly when headlights are on, instrument cluster gauges occasionally read incorrectly.
A/c issues: the a/c cools fine, but I occasionally hear a growl when the a/c kicks in and I have the hood up to hear it
Code issues: Cat below efficiency code, which can usually be ignored, but also a gross evap leak code that I can't track down. I also replaced the fuel cap, but no joy.
The front end needs to be rebuilt--the rubber grommets went a long time ago, and I'm getting noises from the front end when I go over a dip or a speed bump.
All of this is annoying, but for now, can be ignored.
And then today...the kicker...the front timing cover gasket is leaking pretty badly from the driver's side only...probably about a drop every 5-10 seconds. I replaced the front timing cover gasket about 4 years ago and have only put on about 10000 miles, so this is very premature and very unwelcome. I tried torquing the timing cover bolts above the offending water jacket, and they did snug down about 1/2 turn, but the leak is still present. The oil looks fine, and the passenger side is dry as a bone.
I guess I'm at the second to the last stop...I'm going to put in some stop-leak and hope that buys me a few months or years, and do no further repairs on anything. Kinda sad about it...it's been a great vehicle and I really love having the ability to move cargo easily without having to have a pickup, but...I know what my Dad would say if he were still around. "It's nickel and diming you...dump it!"
It's not about the money...I'm going to lease a new electric car as soon as I find a good deal. I just thought I could keep the Explorer running more or less forever, but as I was out there just now...blazing hot sun roasting my back, blazing hot engine scalding my front, I realized...I'm done.
