TB2K
- August 8, 2009
- 96 eddy 4.0,4x4
Ok I went to clean my MAF today because I thought it was a good idea since the prev owner never had an air filter in it for some unknown reason, and because I read a dirty one can cause some drivability issues. When I pulled it the wires were black on the side facing the filter box. after cleaning and using up both sides of the swab, I decided if it was that dirty I better check the IAT sensor (assuming thats what it is, sensor in the intake tube before bend into TB) and it was even worse so I cleaned it and went theough 2 swabs! I then cleaned the tube out and the maf and filter housings and let it all dry reassembled and reconnected the battery. drivability increased 110%! and the dpfe code I had hasen't come back yet, could the computer have been tricked into this code due to the dirty sensors? Also I think cleaning the inside of the engine is now a good idea, I remember reading something about foam you spray into the TB let set then start engine...can anything go wrong when using that stuff? is it 100% safe?
