Capman2k
- September 3, 2002
- Cheyenne, Wyoming
- 00 Ranger XLT
This has actually been going on for over a month, but now it's just annoying as hell...
#1: Every so often the check engine light comes on.. It'll stay on for a few minutes, go off, come back on, go off... You know the drill... Anyway, after the light has come on, if I put it in Neutral or Park it idles up to about 2,000 RPM's. Other times the check engine light doesn't come on, but it will idle in park or neutral at about 2500-3000 RPM's. Sometimes it just idles normally (between 500-1500 RPM's) Not sure what's going on, but I'd like to fix that.
#2: This one is less annoying and there don't seem to be any side effects. If I do a hard brake, or have the brakes depressed for over a minute or so, the Brake light and the rear ABS lights come on. After I do the hard brake, they usually go off. But if I'm sitting with the brakes on, the lights will not turn off... Any ideas for that?
Head gaskets still need to be replaced soon... Otherwise I can't think of anything else going wrong with the X...
