Couple Problems that i have!!!! HELP! | Ford Explorer Forums
HarderThanARock
Superior, Wisconsin
1991 Explorer sport
OK, So here's my first problem......I have had this problem for quite a while. But here's what happens. when i'm taking a right handed turn and when i'm appling the brakes I hear a click........just one click that's it, nothing more. I'm convinced that this problem is related to my truck pulling to the right while i'm driving straight and pulles even harder when brake.
My second problem is..........I just bought wheel spacer, a set of 4. I went to put them on today and after i put the spacer and wheel back on i didn't have enough stud left over in order to put the lug nut back on. How big of a stud should i install so i get the proper amount of stud sticking out?
Answer to problem number1 is radius arm bushings. Do a search and you will find alot of info on them.
Second, and I dont mean to sound like an ass but, Take one of your studs out measure that then add the thickness of the spacer and this will give you the length of the new stud you need.
Yeah.....I had my radial arms bushings replaced and it still pulles........i've had my upper and lower ball joints replaced....i've had the alignment check numerour times.....i've also had the tires filled around just to see if one of them was the problem and it wasn't. Every person that i have talked to about that has absolutely no idea was is the matter with my truck. Someone that i do know at work mentioned something about a tie-rod or inner tie-rod.
After i send out that mesage i relized that i had to do was just take the stud out and messure it and all that type of stuff. Thanx anyways though. Hey, how would you recommened get a stud out?
