That could be bad reception or weak signal but if this is new and now occurs in the same areas where there was no previous issue then there may be a problem. Does it happen on all calls, even ones that you initiate? Have you checked the antenna area?
Although it shouldn't affect this issue, have you updated to the latest MFT release, V3.2.2 ?
