Creaky Noise - 06 Explorer XLT. | Ford Explorer Forums
FireUpRob
Dallas, TX
2006 Explorer XLT
Hearing creaking noise from the bottom of the vehicle when the car is in motion. Sounds like it's coming from the suspension .. not sure where or how to solve the issue.. also on separate issue I hear a loud clunk from the bottom of the veh once in a while... usually happens when i take off or stop .. any suggestions? Thanks
welcome
Similar issue.....
Hi there.
This is the case with my truck too. How big of a job is this? Mine is the left side only. Does it make sense to replace both sides at the same time?
my 2006 needed to have the front control arm bushings lubricated, which solved a creaking noise which was most obvious when making a sharp low speed turn into a driveway apron.
