rmkilc
- November 5, 2018
- Vancouver, WA
- 2015 Ford Explorer Sport
My 2015 Explorer's cruise control speed does not match the speedometer. With it set at 60 mph, the vehicle's speedometer shows a little under 59 mph. I know analog speedometers have a tolerance range, but I pulled up engineering test mode and confirmed as shown below.
Just to make sure adaptive cruise control wasn't causing this, I disabled it. Same result.
I did find a TSB. TSB #44856. But it doesn't say much and leads me to believe it is only talking about the analog gauge which we know aren't perfect. I don't see why a digital cruise control speed shouldn't match the digital speed of the vehicle. I could understand fluctuations below the set speed as it adjusts for the terrain, but it is constantly over 1 mph off. I even set the IPC to kilometers to see if cruise control in kilometers matches the engineering test mode km/h readout to see if perhaps Ford programmed the vehicle in metric and accuracy is lost when converting to imperial due to rounding or something. But the same issue exists there too.
Does anyone know a way to calibrate it?
