d35 carrier for 4.88 gears | Ford Explorer Forums
patrick112390
Alpharetta ga
97' mountaineer 5.0 4406
i am finally getting together things for my gear install and i once heard a new carrier was needed if going to 4.88 in the d35? where can i get that if i need it? current gears are 3.73
somebody has got to know somethingggggg
Why do you need a new carrier? The 4.88 should fit as far as I know in the stock one.
Some bigger sized thick gears call for a carrier that is used for 3.73 at a minimum, but I haven't seen where that is called for in the D35.
ok well i guess we will find out, i have my gears on order and axle on the bench.... lol i will post back regardless of the results
-yep the work with the stock carrier
