Dash Guage Issue with Battery Indicator | Ford Explorer Forums
mercer123
PA
2004 Ford Sport Trac XLE
have had my dash out once and repaired was working find. The Battery Gauge has gone passed the stop. Does any one have the steps to fix it? Resolved similar issues?
you can try pulling the cluster and taking the clear faceplate off. then, carefully and gently push the gauge back. you shouldn't meet hardly any resistance.
I recently worked through gauge related issues, including an inoperative voltage gauge, also a dead oil pressure gauge and fuel gauge. I had my cluster rebuilt by RT Grim in Pennsylvania and had a pretty positive experience with them.
they replaced two meter movements, the microprocessor, connectors, and some other unspecified components.
if manually resetting doesn't work, that may be the answer. lots of 04-05 sport trac's clusters are going bad these days.
GT Rim just repaired this cluster about 5 months ago. They are saying it blow the stop and to turn it counter clockwise back into position.
why would disconnecting the battery reset it and put it back to zero?
