Dash Lights | Ford Explorer Forums
Dash Lights
Dean_
coq
95 xlt
Hey my 95 Explorer XLT 4x4 has no dash lights
when i turn the headlights on the headlights turn on fine... the tail lights dont light up.. the brake lights work.. but i get no parking lights and no dash lights..
anyone know what this could be?
thanks
my best guess is the head light switch. My dash lights wouldnt come on , I didnt check the park lights though, changed the switch and its been fine since.
Ususaly when your tail lights don't work your dash lights don't work either its probably a fuse.
I had the exact problem a couple years ago and it was a fuse ;) I dont remember the exact fuse
i checked the fuses i thought it would be
so unless it was a wierd fuse
It could be the switch. Mine had that problem. I figured it wasn't the fuse because if I jiggled the switch a little by loosening the switch at the dash, the lights would work.
So if it isn't the fuse, time for a new switch.
Slade
How is this a 911 problem?
It is probably the switch.
I have the same problem as the DEAN above does on a 2001 Sport Trac. Can some one help me with what fuse it might be? The dimmer switch seems to work still (over head light comes on when I click the switch over) so I think it must be the fuse. I don't have a fuse diagram so I was hoping someone could help.
changed the switch and it fixed everything
thx for the help
