dash problem........ | Ford Explorer Forums
romangod2326
ohio
02 ford explorer slt
i have an 02 explorer xlt over the weekend the gauge cluster went out it lights up and the abs light and stuff comes on but gas, tach, speedo, and odo, does not move, none of the windows work either we check all fuses and relays and they seem to be fine. i have no idea what the problem is and i am hoping it is not a wiring problem any help please will be greatly appreciated
You could try to reflash the computer or their is a software update that needs to be done. You could also have a bad cluster or computer. From 2002 and up everything runs through the clusters on Explorer's and same with alot of the Ford products. So when the cluster goes bad it makes alot of things go nuts.
