B94Sport
- November 27, 2000
- Geneva, IL
- 05 Subaru Impreza WRX STi
This one has me stumped...
Last night around 6:15, I drove my truck home and it started and ran fine. Parked it, came outside this morning at 7:15 to start it and go to work and...
Nothing. I turned the key and nothing (not the dome light, radio, etc.) turned on. The starter also did not click whatsoever. It was like I didn't even have a battery in there.
Undaunted, I retrieved my portable charger/starter unit from the back. Hooked it up, waited about half an hour and tried to start the car. This time I got the radio and dome lights, but the car would not turn over. I'd get a few clicks from the starter but the voltmeter would drop down so low that that would quit soon as well. I checked the voltage in the battery wires (which I have upgraded - they are not stock, they're 1/0 gauge) and it only read 6.5 volts.
I waited for my roommate to get up so he could give me a jump... Hooked his truck to mine, and the voltage measured 14.9... Let it charge the battery for a while, and tried to start the truck. Got the same result - clicking starter, working dome lights and such... We let it sit some more and it was still doing the same thing.
Finally we pulled the cables off and checked the battery voltage - 13.3 volts, but the truck would not turn over!... I am going to check it again when I get home, and I bet $5 that it's dead again and I need a new battery.
What do you guys think? This battery is only 2 years old, so I am skeptical, but what else could it be? I know cables are fine, starter must be working because it's trying to turn over, just not getting enough juice.
