nealhodge
- March 22, 2005
- OXFORD, MS
- 97 XL CONTROLTRAC
97 ControlTrac Auto 4WD when letting off the accelerator there is a grinding noise coming from the transfer case I suppose. After this you hear the noise in reverse and the vehicle will not back up. I have quickly learned to deal with this by accelerating lightly while braking to stop grinding noise. If the vehicle will not reverse then I can change to 4WD Low and this will work until the range selector is put into high and it starts the grind again on decel. I depend on this vehicle and know this will cause great damage if left unattended if not already. Suggestions would be appreciated.
