Retire55
- November 5, 2006
- 91 XLT
Assistance please.
My 91 XLT (105,000 miles) keeps losing coolant fluid (close to a litre a month). There are no telltale signs of smoke from the exhaust and no visible leaks. I've had the coolant system pressure tested twice without identifying the problem. Next the dealer drained the oil, removed the oil filter, dropped the oil pan and left the vehicle sit overnight to see if any coolant made its way thru. Nothing. The used oil from oil changes looks normal and the vehicle runs fine. I'm concerned that if this situation isn't resolved, there will be serious consequences. Are there any tests that can be performed that might point to the potential problem? Or must I bite the bullet and have new manifold gaskets installed as a pre-emptive measure? I'm no mechanic - consequently all suggestions will be much appreciated. Thanks in advance.
