2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Air filter cover
I modified the stock air filter cover by cutting out a large section and then attaching a piece of aluminum with a 100 degree bend and the upper half section of a bleach bottle.
Then I added several layers of fiberglass tape and epoxy left over from a wood boat building project from many years ago.
I applied a couple coats of Fusion for plastic spray paint.
In a year when I clean the reusable Amsoil air filter I may smooth the outside and spray again for better appearance.
I was unable to find a 4 inch diameter friction fit gasket to attach to the cover so I made one out of 3/8" dia. nonporous caulk saver. I cut a length a little shorter than the dia. of the MAF sensor adapter tube. Then I glued the ends together with a short length of 18 gauge, insulated, stranded wire poked in each end to keep the ends centered and together.
