UPDATE:
So I pulled the blend door actuator and it is functioning correctly. When I had the glove compartment pulled I visually inspected the wiring and nothing appears to be fried. The motor still cycles through the fan level settings so that tells me the blower resistor/motor is fine. Also, when I have A/C selected it does get cold, but when heat is selected there is no heat. So the actuator moves the blend door to the heat side but there is no hot air in the cabin (other than what I generate!) Now, I'm again assuming this is electrical in nature per my description earlier in the thread and the initial event. So I don't think it is heater core related. Would I be correct in that assumption? If so, where else should I be looking? If not, same question. I have checked all the related fuses and none are blown. I've got to get this figured out as the cold weather is coming soon here in Texas! My God, it's going to be into the 40's this week!!
Thanks for any input.
Chef Duane
