Kriegen
- August 24, 2009
- Montgomery, AL
- 1999 Mounty 5.0L AWD
I have a 99 Mountaineer and while I was driving, a high pitched ringing alarm started sounding in the cabin. I pulled over and turned off the engine but the ringing continued and the car would not start. NOTE: The ringing is not a perimeter alarm and is hardly noticeable outside of the truck if the doors are closed
On the instrument panel, the voltage level looked a bit low so I checked the battery and noticed the terminals were cracked and in bad need of replacement. I was able to get someone to jump me which worked no problem and was able to get home.
Took my other car and got some new terminals, put them on and reconnected the battery. I used a voltmeter to check the battery and it was reading 12V but the engine would not crank, just a single click like the battery was dead.
Additionally, the only time the ringing stopped was when I had the battery disconnected and later after going over the fuse boxes, it would stop when I pulled the fuse for the ignition switch but it restarted as soon as I put the fuse back in.
I plan on tomorrow checking the voltage at the starter to see if there is a problem somewhere in the battery cable but don't know what might be causing the alarm.
Thanks for any assistance.
