geomuf
- April 13, 2008
- Hillsboro, OR
- 02 XLT
Anybody ever use Detroit Axle/Dearborn Axle for parts?
I recently purchased a pair of CV Drive Axles for my '02 XLT and have to say I am disapointed. These were re-manufactured axles so I understand they will not be perfect but I believe this is a bit too far. They claim to chase the splines and threads but the condition of these axles makes me question that. The threads on one of the axles has visible damage and the other had rust in the threads. Both of the differential ends still have the original retaining rings in place. This is obvious due to the grime under them as they are turned. With these rings in place and obviously never removed, it is obvious the splines were not chased. They metal parts are spray painted with a grey paint to make them look as if they were sandblasted. It is obvious this isn't the case as their is rust and grease/grime under the paint.
This was the kicker. one of the hubs at the wheel end had a suspicious rough area around it. At first I thought it was rough casting. I picked at it with my finger nail and a ring of rust popped off.
Here is a shot of the threads.
I haven't compared against the original parts as they are still installed but the replacements have different diameter shafts on them.
I do not think I will try them again and will be searching for replacements.
George
George
