bluestack
- March 8, 2007
- 91 xlt
Hi,
I'm back again, and Glacier saved me a fortune the last time - but this time - not such an easy fix, and could with some more advice before deciding what to do.
Bit of hist:
Had a problem with a slipping solenoid (drive and overdrive), which after some advice from Glacier, turned out to be a burnt wire grounding.
Anyway, this time.....
Pulled into the car park, felt the tranny labour, or slip slightly - pulled into a space and saw a line of drops which after checking the under the car was leaking from between the tranny. Sorry for the laymans terms - but where the slighly funnel shaped section connects to the front boxy shaped section just under the engine (if it wasn't late and dark I'd have taken a pic).
Anyway - I had to get somewhere - so I let the car cool down - checked the tranny fluid, which had loads, and got going again - no problem with slipping this time.
Checked for further drops along the way and nothing - until boom - it just started slipping and wouldn't engage - cue lots of blue smoke out the back - tranny oil on exhaust ???
Pulled into another car park and checked - this time loads of leaking underneath, would engage - but no 'pull' in either drive or reverse - although the initial clunk as it engages was there.
Need to go back and get it sorted - any ideas ?
And also anyone know/recommend anywhere near Springhill/Brooksville down Florida way ?
Thanks.
P.S
'91 XL, 4wd, 160k miles
Bit of hist:
Thanks.
P.S
