Disable 4w ABS 1994 Ex EB | Ford Explorer Forums
leefhead
Sudbury,Ontario
'94 Eddie Bauer
How do i disable the 4 wheel ABS in my 1994 Ex EB? that stupid abs has gotten me into an accident in the past and kepts on making me almost hitting people. if i hit the e-brake, i stop immediatly. anyways. how do i disable it.
i researched like crazy, posted, now i figured it out...here's a tutorial on how to do it. all pics were taken with my camera phone (samsung d807), quality is good, but not perfect. im sure it'll be good enough though.
turn your vehicle off, open hood, raise it, this is what you'll see :
look at the rear passenger side of the engine bay, and you'll see your power distribution box.
now, of you open it (by swinging it back, pull up on the tab on the front of the box), you'll see this
look at the relays
the relay on the bottom, left, and the one on top of it, are for the abs system. i removed both
and your all done! if your wondering what the other relays do, look under the plastic cover.
I attempted pulling both, and my EX would not start afterwards.
Put both back in, and it started.
If you're not careful you may pull the fuel pump relay by mistake. Check the diagram on the fuse box lid. Also note that the fuse box design changed midway between 1991 and 1994 so yours may differ from the pictures.
