disable 4x4 AUTO? | Page 6 | Ford Explorer Forums
disable 4x4 AUTO?
tuffenuf83 said:
I have a 2000 XLS, so will this brown wire mob work for it. In the exact same pics that were posted here on page 2, I think. I havent read the long write up (25 pages), but what I have here should be good enough dont you think?? ALso if someone has a pic of there dash, with the LED installed can you post it, just to see it. Also if there is any caution, or warnings before i do this, please fill me in. Planning on doing it this weekend or next!
Thanks
Works for all X's with control trac (auto, 4wd high and 4wd low on the dash switch). If you are going for the bw in the dash you should probably wire it after the splice as gijoecam mentions at the end of this thread...that's if you want true 2wd low. If you are only interested in 2wd when in auto mode then you can wire it before the splice.
Most have just wired in lighted switches...mine is mounted under the dash next to the center console...sort of above where your right knee/shin would be when driving. Briwayjones and some others mounted the swich in the radio bezel where the cigarette lighter would normally be. I believe briway has a pic of his mounted switch somewhere on the board.
Only warning I can think of would be to disconnect the battery since you'll be working near the airbag and you don't want to set it off.
Lee
