racprops
- January 25, 2019
- Phoenix AZ
- 2003 Explorer XLT 4.6 4WD
Well I am going into the wild Unexplored again.
So it DOES SEEM I have a better chance of finding out about the UFOs that reported crashed in Roswell that decoding the parts numbers of a 03 Ford Explorer’s PCMs to match up a 04 PCM to my 03 PCM.
I need this so my transmission guy can install the newer Solenoid Pack as the correct one for my 5R55S transmission is no longer made, and if the newer Solenoid Pack is used there is a 30% chance of a mismatch between it and my older PCM.
So best the idea is to get an 04 PCM from an Explorer with a 4.6 V8, 5R55s, no info center in dash, and a 3.73 rear end PCMs, disable PATS so I can test it in my truck to see if it will run and drive.
To do these tests I need to disable or remove the PATS from a few 04 Ford PCMs.
There are a bunch of wackadoole ways on the internet on how to do this, I need the cheapest DYI system that really works as I may need to try a few to get the best match.
Anyone done this with any 04/05 Ford PCMs??
This will be important to everyone with a Explorer made before AUG 03 and even wants a GOOD transmission rebuild.
Rich
Rich
