Explorer_PL
- November 16, 2007
- Rockland County, NY
- 06EB V8
Hello everyone -
It does not look like our 06 v8 is leaving the family anytime soon since my youngest driver in the family inherited it from me with just 300k and she likes it.
It's running strong, transmission shifts great (still OEM), the only issue is that the current engine that has about 150k smokes a little oil on the startup. I am pretty sure the valve seals are the problem, I don't need to add oil so the consumption is minimal, it just stinks when you start it. I'll probably do compression test to rule out piston rings but assuming all checks out, I want to replace the seals. Since I'll be there, I plan to also replace also lash adjusters and roller followers, because .......because it's my daughter's car now and you guys know how that goes, it needs to be almost perfect
Anyway, I am hoping for the real techs (BoominX - are you there ?) to chime in here. Can I do all that with the cams in place ? Also, can I use pistons in TDC to support valves and do a cylinder at a time or compressed air is recommended ?
I appreciate and welcome any hints and advices.
Thanks
PS: And valve springs .....
Thanks
