- October 12, 1999
- Pennsylvania
- 2024 F-150 Tremor
Symptoms:
Last year I replaced my tires and had the front end aligned. The tires have been rotated at 5,000 miles and 10,000 miles, respectively, and do not show signs of cupping or improper wear due to inflation or deflation.
Prior to the front right wheel making noise on a straight path, when I would turn, I could hear what sounded like the right front tire running on rough pavement. That is to say, I could hear more road noise than I was accustomed to hearing. I initially brushed it off as me being paranoid, since most of us familiar with cars pick up on the slightest noises.
Now, at low speeds, it sounds like the front right tire is riding on concrete pavement. The pitch of the sound varies with speed, but it is most easily heard at low speeds (0-45 mph) due to the lack of road noise. This noise seems to come and go away after a while; it most easily is repeated from a cold start and drive.
My front hub assemblies are the same as when I purchased the Trac new. So, they're old: 8 years, 85,000 miles, and a true four seasons. I do off-road the Trac occasionally, so the front has been stressed more than a highway queen.
Thoughts:
Quite simply, I'm leaning towards the hub bearings. I base this on a Subaru whose bearings were shot, which made it sound like the tires were running on the roughest finish concrete highway: loud. Not grinding, but imagine the sound you would hear dragging a couch upside down your vehicle.
They are not separable from the hub, so I will need to replace the entire hub assembly.
I've narrowed my replacement to "National", which Advance sells. I can't beat the cost: $135 less $40 from one of their always fantastic coupons. They carry a 3-year warranty. From what I can tell on Rock Auto, Moog's used to be branded National, so one manufacturers for the other I presume.
(Or, should I just go with Timken?)
Well?
Well? Am I on the right track?
And, should I replace both? I assume I'll need to get the front realigned when I am done.
And moreover, does anyone have an impact gun or massive torque wrench I can borrow?
Thoughts:
Well?
