documentation on drive train | Ford Explorer Forums
patarch1
West haven ct
97 Ranger
Hi,
I am looking for a detailed or exploded view of the front drive train of a 97 ranger 4*4.
I have a Haynes manual but it is not very clear.
Thnks in advance
Patarch1
what exactly are you trying to figure out? i have a workshop manual with exploded views here but its pretty worthless...and its probly the same picture you have in your haynes manual
Item Part Number Description
1 — Differential Ring Gear (Part of 3222)
2 357228-S Lock Pin
3 3204 Differential Case
4 3L222 Ring Gear Bolt
5 — Drive Pinion (Part of 3222)
6 3B067 Oil Slinger/Selective Shim
7 4621 Pinion Bearing Cone and Roller
8 4616 Drive Pinion Bearing Cup
9 3070 Oil Baffle
10 3A067 Differential Bearing Shims
11 D6AZ-19562-AA or -BA RTV Gasket Sealant
12 3010 Carrier Housing
13 — Bearing Cap Bolts (Part of 3010)
14 — Bearing Cap (Part of 3010)
15 4222 Differential Bearing Cup
16 4221 Differential Bearing
17 3A222 Collapsible Spacer
18 3070 Oil Slinger
19 4676 Pinion Seal
20 4859 Drive Pinion Oil Seal Deflector
21 4851 Axle Companion Flange
22 356504-S Companion Flange Washer
23 3T222 Companion Flange Nut
Hi,
I would like to understnad what's between the transfer case and the wheels to understand why when I lock the front wheels, they "whobble" and the truck feels like a noat in rough seas
Patarch1
