Does a 2015 PIU transmission have a replaceable filter? | Ford Explorer Forums
atikovi
Mclean VA
2015 PIU
With the 3.7L engine. By replaceable I mean without taking apart the transmission. And are the fluids changed on the transfer case and read axle?
By transfer case, I'm guessing that you are referring to the PTU? If so, members have changed the fluid in it. There are several posts on that in the 'Discussion' forum. There is also a post about a member changing the fluid in the rear differential.
As for a transmission filter, I don't know about the 3.7 but the retail Explorer doesn't have one that is serviceable.
Much of this has already been discussed and can be found using the forum's 'Search' feature. There are many more on the PTU fluid change.
