dome and interior light question | Ford Explorer Forums
chrisw2012
tn
2003 sports trac
So I searched and couldnt find anything that was useful... im wanting to redo all my dome lights. There is the 2 differant lighting units one between front seats and one in the bsck. And there is a set of lights that come one when door opens and I differsnt ligjt for when you flip the switch. My questions is does anyone know the bulb #'s for either set. Im wanting a bright green color for the ones that you flip the switch and im wanting a cool white or looking light for when you open the door. Does anyone know of they are just plug and play or what? And can anyone know a link of step by step how to do it the easiest way possible.
Okay im confused with all the lamp and map lamp dome lamo and all that which ones are the ones the you csn flip the switch which ones are those called and when you open your door or turn your lil knob for dash ligjts all the way up and the inside csb lights come on what are this called
In normal circumstances the dome lamps are the ones that come on w/ an open door/remote unlock. The map lights are the ones up front that you switch for individual driver light or pass. Map light, I believe, comes from the light you would turn on (use) at night while driving (or not) to look at a map, it's light output is focused as to not distract the driver (that's if the passenger is using the light to read the map) but focused point not scattered.
Most will use 194
Okay thanks does anyone knoe or have a write up of how to tske it doen properly eithout braking stuff
It's pretty simple dude, for the most part you find the indent in the lens and put your small flat head and pry off
Awesome thabks for the help
