dlt0028
- April 8, 2014
- Detroit, Michigan
- 2013 Ford Explorer 4WD V6
The issue is Ive taken to the dealership 3 times because of it. They clean it and send you on your way. I don't know about you, but I don't like taking off work to keep getting this fixed. Losing vacation time and money over a $5 part. After its out of warranty, they want up to $500 to fix it. They know its a problem, but dont fix it right the first time. If its just grinding off some of the button on the sensor, why doesnt the dealership do it? Add the fuel pump, the door latch recall, the brakes squealing because of a design problem (only 15k miles on them), and problems starting when its below 30 degrees, and the battery died before I even left the dealer lot. Just a poorly built designed vehicle that I'm stuck with until Jan 2016.
