jarena
- March 18, 2006
- boston massachusetts
- 2002 eddie bauer
I have a 2002 eddie bauer with 88,000 miles. Recently had a problem with the drivers door pin switch- replaced the switch and problem was resolved. However now a new problem has cropped up. I cannot lock the doors with out the key being in the ignition. When I remove key and try to lock doors from inside the switch is dead. I don't have the fobs(long story) so I cannot use them to lock doors. I can only lock doors manually with the key from outside. The drivers door switch is dead but the passenger door works. Thanks!
