01explorerv801
- November 5, 2008
- CT
any way make a long story short i have been in the process of replacing my passenger side ex manifold, and gasket due to massive corroding and nasty blow through, any way after pb blasting the **** out of it for 2 days i still ended up snapping 2 of the bolts by spark plug 3. so today i started to drill the bolts out because it was the only option left. so i got the first bolt drilled and tapped, started with the second next size up drill bit and wham coolant starts dripping out.... wtf ... lol.. i have had it up to hear with this lemon. anyway i luckily had a sheet of lead from my old body shop so i cut of 3 3/8" circles pressed one in all the way into the whole and used one of the old nuts to press it in, repeated this with 3 pieces total. any way, it has stopped leaking, but i still want to put some sort of sealant or something to make sure it doesnt leak.
what should i use? rtv, exhaust fix puddy? any ideas guys? i want to get this done tomorrow so i can take it to work to make sure it drives correctly.
also i have 2 sets of gaskets for this thing, the ones that came with the manifold are these thin metal looking ones similar to stock. the others i bought are from pepboys and look to be made out paper and are thicker than the other ones. which ones should i use?
