AJ168
- March 31, 2011
- Allentown, NJ
- '05 Sport Trac XLT
I did the U-joints on my rear drive shaft the other day and screwed up thinking that the drive shaft would pull out of the transfer case, when it really pulled out about a third of the way back. I had everything marked, except for right there. I was able to get it back close to it's original position, but it has to be off by a little. Going down the road, there's a slight vibration at 50 mph, then again at 70. It's noticeable, but only on a smooth road. Question is, is it worth pulling it back off and getting it balanced, or will my new u-joints and transfer case seal be safe with just a little vibration?
If I should balance it, is there any way i can make something up to do it myself?
