Chris1955
- July 4, 2007
- Akron Ohio
- 98 Ranger XLT
I've got a '98 Ranger XLT, 5 speed manual transmission, 2 wheel drive, 2.5 liter engine, approx 156,000 miles. Over the past few months, I had 3 or 4 instances of difficult shifting, going from 1st to second. Two weeks ago it would not shift into first from neutral. I was able to force it into second, and limped home in second. It would not shift into any gears with the engine running. I removed the transmission, pressure plate and clutch. The clutch was damaged, one of the springs had come free and was lodged in the pressure plate spring fingers. I replaced the clutch, not the pressure plate (it did not appear to be damaged). I put everthing back together, bled the hydraulic clutch system. My problem is that I cannot shift from or into any gear with the engine running with the drive shaft in place. If the drive shaft is removed, I can shift smoothly into all the gears with the engine running. I opened up the differential case and found no problems, everything turns smoothly. I take it that I have a transmission problem - my plan is to get one from the auto wrecking lot ($350 to $450). I'm not a transmission guy, but would be willing try to fix it myself. Any thoughts about what might be wrong, and if I could fix it for less than the cost of used transmission? Thanks.
