Concentricity
- April 26, 2022
- Houston
- 2001 Explorer XLT
This has been aggravating me all day. Driver door will lock with remote, but will not unlock except by manually pulling the handle from inside. Took off the door cover and looked inside, seems to be that the clip connecting the key lock to whatever it does keeps popping out, and the door lock indicator is not moving nearly as much as it should be. It makes noise and slightly shifts when i use the remote, but won't actually unlock the door. First picture the white clip is disconnected, second picture I connected it and it disconnects when i try to unlock it with the key, and doesn't stay connected unless i push the thicker bar next to it up literally like a quarter of an inch. I'm so confused, I don't even know what the real problem is here.
