Drivers Door Keyless Entry Keypad Removal | Ford Explorer Forums
nleipziger
Langhorne, PA
2006 Eddie Bauer
Hello All..... Some of the keys on the keyless entry keypad require too much force to register, anyone know how to remove the keypad? It looks like it is just pushed in. Thanks for helping.
Neil
I see you have a 2006 explorer. here is some instruction from alldata on how to remove keyles pad. hope this helps.
Removal and Installation 1. Position the front window glass to the full down position. 2. Position the door glass top run aside to access the door pillar trim panel screws. 3. Remove the 3 door pillar trim panel screws and the door pillar trim panel. 4. Disconnect the electrical connector and remove the RKE keypad from the door pillar trim panel. 5. To install, reverse the removal procedure
