sall
- April 3, 2009
- The Burg
- 1998 Mercury Mountaineer
Alright guys, I'm new here and I own a 1998 Mercury Mountainer 4WD 5.0. I am having a problem with the power door lock on the drivers side.
About a week ago the power lock quit functioning correctly. When I would go to use the key fob I had to push it sometimes 5-6 times to get the drivers side door lock to pop open. So, I figure the door lock actuator needs lubed up or it is going bad.
I start my diagnosis by pulling the door trim off and pulling back the other insulation so I can see what is going on inside. Alright no problems there just as easy as pulling trim off any vehicle if you have the right tools.
I cycle the door locks with the door open. Everything works fine on the first try. Door Locks. Door unlocks correctly. I then close the door. Door locks correctly. I then try to unlock. Door will not unlock when door is closed until i cycle the locks several times and it will finally pop up.
Out of curiosity I decide to clean out all the old grease in the door lock part that hits the striker to lock the door. I blast it with some brakleen and apply new grease. I also decide to pull the rubber up off the actuator and give it a good spray with silicone lubricant. Still the same results. Door lock works perfect with door open. Does not work correctly with door closed.
I am at this point thinking that the actuator is not functioning properly and is on its last leg. Not providing enough umph for lack of better words to pop the lock when the door is closed.
I purchase a door lock actuator from local auto parts store. Takes an easy 20 minutes to replace the actuator. Just to note you do not have to drill out the rivet to replace the actuator. You can just pop it out of the bracket that holds it in and pop the new in place. Of course after removing the window guide.
So, I reconnect the negative battery terminal and cross my fingers that everything works properly. I test with door open first. Everything works fine. Cycle locks several times same result working fine with door open. I then shut the door and cycle locks. Locks fine. Go to unlock and same result as old actuator. I have to push unlock several times for it to pop open.
I then take a break because I am pretty irrate at that moment. Come back out a few minutes later and try again. Same result. I decide I will try opening the door from the outside instead of sitting inside and cycling the locks.
Okay, door is shut and unlocked. I proceed to lock the doors and try to unlock it. Bam! Opens right up. Try it a few times working properly I scratch my head. I then sit inside again and try it out. Working just fine. I then open the door from the inside and then close it. Cycle locks again. Once again the door does not unlock. I realize what I am doing different. Pulling the handle to open the door. So, I wiggle the inside handle and sure enough the door locks pops open after I push the unlock button.
Right now I am thinking that my issue is somewhere with the inside door handle and the rod. The other option is that the door lock part that hits the striker is not functioning correctly.
What do you guys think? Should I replace the rod that runs from the inside door handle? Or replace the locking mechanism that hits the striker to lock the door? Any help greatly appreciated as this is bugging me and not doing my other door lock actuators any good by constantly cycling the locks to get the driver side to pop open. Thanks in advance!
