Scannerboy1968
- November 13, 2005
- FL
- 98 Explorer Limited
I have a 98 Explorer Limited. It has 180,000 miles and I recently experienced a front hub bearing go bad (thought I was going to loose the wheel from the terrible sounds it made). Anyway got that problem fixed and drove it for about 3 weeks before the next problem started.
Upon quick acceleration off of the line, there is a very load deep bang in the drivetrain (almost like a U-joint breaking). After you get up to speed, everything is fine. Also if you take off gradually up to like 20 or 25 and then accellerate, everything is fine. Being a full time AWD, my theory is it might be a duel ratio transfer case and the lower ratio is having a problem. What are your thoughts on problems ?
Thanks, Andy
Thanks, Andy
